Can the AWD linkage freeze?
Old Feb 2, 2007 | 02:08 PM
carlover626's Avatar
Default Can the AWD linkage freeze?
Hello all newbie here looking to see if I can have some input on my AWD / 4-H issue.
The current temp here is like 5 degrees, and on my way to work I attempted to shift from AWD to 4-H...correctly I might add.
In doing this the stick moved a little, closer to the 4-H position although the light is not on and I am unable to move the stick either up to what I think is 4-H or back to the AWD position. [sm=WTFsgign.gif]
I understand it could be frozen (dealer said that this morning), but am I safe to be driving it? I have a trip (about 200 miles) tomorrow and I don't want to hurt my new baby!
Any advice?
Thanks! Mike
Old Feb 2, 2007 | 02:31 PM
off roader's Avatar
Default RE: Can the AWD linkage freeze?
What vehicle do you have?
Old Feb 2, 2007 | 02:50 PM
Sorry, didn't realize the profile isn't here...
It is a 2002 Montero Sport LS, AWD 3.0 L.
Old Feb 2, 2007 | 07:25 PM
Well, on my own I have figured out that the lights (4H / 4L) are not operating when I start the car, from what I have heard from THE DEALER [:'(] is that they should come on when starting.
I have an appointment tomorrow morning with them, I'll let everyone know why this is happening.
Old Feb 2, 2007 | 08:04 PM
off roader's Avatar
I didn't respond further because I don't know your xcase that well. I do know that the dash lights are replaceable. Just remove your instrument cluster to access them, but if you're not comfy with that, I'm sure the dealer will happily accept cash, check or charge
Old Feb 2, 2007 | 08:29 PM
Well we'll see if the lights are the problem, cause like I said the stick is no longer movingat all plus the lights are not functioning.
Oh and I have a service contract for the big things, if it is a bulb I'll be happy to learn how to R&R that, I owned a 97 Pontiac Grand Am before this ...
Old Feb 5, 2007 | 11:28 AM
Well the dealer had it on Saturday, and they had to take the shifter assembly apart and "realign" the linkage for the 4X4 selector, I guess this loosens up over time?
I had to bend over at the cashier [:-]...$180.00 for this alignment and the service contract won't conver a non failed part. At least my 4-wheel drive system is working as it should now.
Forfuture referance with others I guess!
Old Feb 5, 2007 | 02:00 PM
off roader's Avatar
ORIGINAL: carlover626
I've not heard of them needing realignment but like I said I don't know your rig as well as I know the full sized montero's.
$180, hmmm, I wonder what exactly they re-aligned and why it would go out of alignment in the first place.
BTW, just to prevent other future problems I hope you regularly lube your xcase, tranny, and diff's.
Old Feb 5, 2007 | 03:19 PM
It wasn't the mechanical peices under the car that you are describing, it was the actual linkage inside the car that the shifter moves to the desired selection.
They had to take the center counsel and the linkage (of the shifter) and replace and tighten the pieces that became loose and made me unable to move the shifter. The lights / 4X4 operation was fine afterward, but the shifter was no longer moving because of this.
Hey,are there points under the car that I can look at to see if they have been lubed or are in need of such?
Does anyone know how many lube points there are on an 02 Montero Sport?
Old Feb 5, 2007 | 08:58 PM
off roader's Avatar
I'd check the factory service manual for that info. The aftermarket manuals like Chiltons, Hayne's, Mitchell, etc. are just not accurate.
IIRC, on my Gen I there are 13 lube points (Zirk Fittings).
There should be close to that many on your sport.
milliesdad
Oct 16, 2014 11:34 PM
marianomontero
Jun 4, 2014 02:05 PM
dannyc
Feb 12, 2010 12:26 PM
GreddyBooster
Sep 27, 2005 05:40 PM
