Cigerette lighters no longer work
Old Sep 2, 2009 | 01:17 AM
Bebopbam's Avatar
Default Cigerette lighters no longer work
I have a 2003 Mistubishi Montero Sport and the cigerette lighters have all stopped working suddenly. I check the fuses in the fuse box under the hood and they all seem fine. Is there maybe a secondary fuse box somewhere or something? I'm open to suggestions.
Old Sep 2, 2009 | 10:09 AM
jrmdir's Avatar
The fuse box in the engine compartment is mostly for major engine and electrical systems. There is another fuse box inside - on the firewall just above and to the left of your left foot. This should be well detailed in your owners manual - if you have one
Ron
Oops - let me revise that now that I've re-read your post. What I described is for full-size Montero. The Sport may be different so others will have to chime in. But in any case the location of all fuse boxes should be shown in the owner's manual.
Old Sep 2, 2009 | 10:24 PM
don_zz's Avatar
Yes, I have a Montero Sport (although it's a 2000 model) but there are 2 fuse boxes under the dash on the left side of the driver's footwell. There is a fuse there for the cigarette lighter.
I rewired mine so the lighter sockets stay "hot" all the time - Even with the ignition off so my wife can leave her cell phone plugged in over night to charge it.
Don
Old Sep 3, 2009 | 01:19 PM
Bebopbam's Avatar
thanks guys I found the secondary fuse box, but I bought the car used (so no users manual) and there is no cover for this one so I have no idea which one if for the cigarette lighters. There are about 20 different fuses, most are 10 amps, a few 15 amps, one 20 amp and one 25 amp. if you guys have any idea which one it is, or where I can maybe find a copy of the users manual I'd really appreciate it.
Old Sep 3, 2009 | 03:41 PM
jrmdir's Avatar
Hopefully a Sport owner can e-mail or fax you the diagram. If the parts dept people at your local Mitsu dealer are kind they might also make a copy for you.
For a replacement manual, try:
www.msrecycling.com or www.books4cars.com.
Ron
Old Sep 3, 2009 | 08:03 PM
jrmdir's Avatar
Look at the photos in this link - I think it has what you need. Fuse 5, 15 AMP
http://msport97.proboards.com/index....ay&thread=4094
Ron
Old Sep 3, 2009 | 11:59 PM
Bebopbam's Avatar
Thanks for the help. I checked all the fuses in the secondary fuse box and they are all good as well. So it's probably a bad ground or a bad relay in either case I'm gonna have to take it to my dealership to get it fixed. Once again thanks for all your help
Old Dec 4, 2012 | 05:16 AM
nevets's Avatar
have 2000 2lt galant estate the cigerette lighter dosent work checked fuse an conection any idea
Old Jun 29, 2013 | 06:23 PM
jonathon75's Avatar
Default Cigarette lighter
Did the dealership ever tell you what was wrong with the lighter? I have a feeling it's one of the reasons I've had to buy/replace 5 alternator 4 batteries and 2 starters. My fuses are good.
Old Jun 30, 2013 | 12:16 PM
Akzle's Avatar
love my mitsi. But it has gone through 3 alternator rebuilds. Something in the electrics is voodoo.
