Climate Control Problem
Old Jun 5, 2015 | 11:11 PM
MitsuMan69's Avatar
Default Climate Control Problem
The problem that I am having is whether it is hot air or A/C, the switch to put the air on max does not work. It works on low and all the other in between settings but it does not work on max. Would I just be able to replace the switch itself or would I have to replace the whole climate control unit?
Old Jun 6, 2015 | 08:21 PM
user 27474884's Avatar
I would first check your freon level on the low side port of your ac lines. It could be as simple as low refrigerant.
Edit: just read your post again, so the max doesn't work with the heat or the ac?
bmerz
Feb 24, 2021 06:55 PM
JOE M
Nov 28, 2006 08:07 PM
fastblatt
Oct 3, 2006 07:39 PM
speedy
Feb 3, 2006 03:56 PM
FireDoc
Oct 13, 2005 06:07 PM
