Coolant temp gauge ?
Anyone know what these wires are? It looks like it sits on top of the coolant intake to the engine. I might have nicked it when taking off the intake plenum to change the spark plugs recently. It looks like a ground of some sort but I can't tell where it connected to. The coolant temp gauge died after I put everything back together so I'm guessing it might be related? Already changed the coolant temp sensor (check out the brand new 'gold' bling in the bottom right of the pic
)Anyway, any help is appreciated, thanks.
Looks pretty easy to hook back up or just use a jumper wire with a small alligator clip at each end as a temporary way to see if it brings your temp gauge back to life. Is that a rubber insulating washer under the side with the black ? If so it's prolly NOT a ground (which I doubt it being).
Sounds like he gave you the answer to your question.
Here is a link to a PDF service manual you can download for free:
http://www.onlinefreeebooks.net/auto...anual-pdf.html
Wiloz32
Jan 29, 2013 01:46 PM
2nd gen spyder 2 gauge pillar pod, autometer lunar boost gauge, and autometer lunar air fuel gauge f
mr casual
Jul 6, 2006 10:59 PM
