Coolant temp gauge ?
Old Jun 20, 2009 | 12:10 PM
wakawu's Avatar
Default Coolant temp gauge ?
Anyone know what these wires are? It looks like it sits on top of the coolant intake to the engine. I might have nicked it when taking off the intake plenum to change the spark plugs recently. It looks like a ground of some sort but I can't tell where it connected to. The coolant temp gauge died after I put everything back together so I'm guessing it might be related? Already changed the coolant temp sensor (check out the brand new 'gold' bling in the bottom right of the pic )
Anyway, any help is appreciated, thanks.
Old Jun 20, 2009 | 01:00 PM
BrokeDad's Avatar
Looks pretty easy to hook back up or just use a jumper wire with a small alligator clip at each end as a temporary way to see if it brings your temp gauge back to life. Is that a rubber insulating washer under the side with the black ? If so it's prolly NOT a ground (which I doubt it being).
Old Jun 21, 2009 | 12:01 AM
jgbrules's Avatar
that IS the coolant temp sensor for the gauge. make a wiring repair and your gauge will start working again.
Old Jun 21, 2009 | 12:58 PM
wakawu's Avatar
Do those connect together or does the one on the coolant pipe need to just be grounded to something? I have no idea where it hooked up to before it broke..
Old Jun 21, 2009 | 02:22 PM
BrokeDad's Avatar
What year is your Montero ? I'd post a service manual link but I'd need that info.
Old Jun 23, 2009 | 12:55 AM
wakawu's Avatar
1998 Mitsubishi Montero Sport LS 4x4 V6 3.0L
Old Jun 23, 2009 | 05:52 PM
Manybrews's Avatar
the upper right is the coolant sender for the gauge.
the lower left USED to be an anchor for the ignition cables until it was shattered.
Old Jun 24, 2009 | 03:10 PM
BrokeDad's Avatar
Sounds like he gave you the answer to your question.
Here is a link to a PDF service manual you can download for free:
http://www.onlinefreeebooks.net/auto...anual-pdf.html
Wiloz32
Jan 29, 2013 01:46 PM
ruski
Dec 30, 2010 05:32 PM
fiveightandten
May 31, 2010 07:54 PM
wolfman
Oct 29, 2004 06:39 PM
