-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   EGR Temp sensor switch 3.5 dohc 24v 1996 (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/egr-temp-sensor-switch-3-5-dohc-24v-1996-a-19083/)
johcalhoun May 19, 2007 11:37 AM
Hi Folks, Newbee here!
My question reguardsa 1996 Montero SR. 145,000 miles. I had a new timing belt & plugs/wires recevtly installed by a (friend of a friend). When I got it back I discovered that the "Temp.Sensor Switch" under the EGR vaulve was not plugged in (electrical) and I can not find anywhere to plug it in to?
The ( friend of a friend ) claims it was not plugged in when he did the repairs. I pulled the upper intake off and still can not see anywhere to plug it. Any help / advise will be greatly appricaited!
Thanks John
mxmikie May 21, 2007 10:53 AM
RE: EGR Temp sensor switch 3.5 dohc 24v 1996
the temp sender is on the front of the engine next to the upper rad hose housing
johcalhoun May 21, 2007 01:39 PM
Thanks,
But not the water temp sending unit. This one is located on the back left of the intake (facing the enigne) under the EGR vaulve.
Thanks Anyway,
John
