Engine temp
Old Apr 1, 2015 | 09:43 AM
charlesdds's Avatar
Default Engine temp
So my coolant temp gauge will only register to the1st line every once and a while-- most of the time it sits at the bottom. I changed the gauge sender unit with no effect-- any other thoughts??
Thanks,
Chuck
Old Apr 1, 2015 | 10:56 AM
Thermostat ether stuck open or missing. It's easy to check it, since it is on the front of the engine and not much is in front of it.
Old Apr 1, 2015 | 11:58 AM
user 27474884's Avatar
Do you have a full size xls/ltd or a sport? If you have a full size montero "not a sport" more than likely its a r10 resistor or the back of the gauge cluster. Where its been soldered tends to crack leaving a ***** temp gauge. This is a very common problem on the full size montero and is easliy fixed by a couple hours, a pencil soldering gun, and a steady hand. Theres several videos on youtube and alot of online info on google.
Old Apr 1, 2015 | 01:23 PM
charlesdds's Avatar
I have a 1991 LWB Montero RS---
Old Apr 2, 2015 | 07:27 AM
Ahhh gotcha, then i'm gonna have to agree with hunter. Probably a stuck thermostat. Sorry if I caused any confusion.
Old Apr 3, 2015 | 12:08 AM
charlesdds's Avatar
Guys-
Thanks for the help. The thermostat was stuck open- replaced it today and the temp gauge works now. Appreciate the help!
Old Apr 3, 2015 | 09:14 AM
charlesdds's Avatar
uggghhhh... spoke too soon. This morning the gauge did not move at all....
Thoughts? I now have a new sender and new thermostat.
Chuck
jrbudmama8
Apr 12, 2013 12:43 AM
HunterD
Sep 21, 2010 11:56 PM
GACosta50
Mar 19, 2010 08:10 AM
UncRamos
Sep 2, 2009 05:40 AM
burnmyeyes
May 5, 2006 08:39 PM
