FAQ Semi-custom Cheap Short Ram Intake For 2001-2006 Montero (not Sport) W/pic
Old Aug 16, 2009 | 06:08 PM
redturboeclipse's Avatar
Thumbs up FAQ Semi-custom Cheap Short Ram Intake For 2001-2006 Montero (not Sport) W/pic
Well, after a quick look there are no specifically made affordable intakes for our vehicles (2001-2006 USA Montero)
Some say they won't do much, others will argue.
Anyways, I could not find a cheap EBAY one. Everyone knows intakes are not hard to produce, it just consist of a pipe and filter and anything needed to adapt your OEM lines and MAF/MAS. The only ones that "might" work are from Weapon-R or Injen but it seems like manufacturers get confused between the Montero and Montero Sport. That and those are $150-200+
So here is mine that I put together..
It almost looks like it was designed for our vehicle right? Well it's not, that is a short ram intake kit for 2002-2005 Ford Explorer V6 (not Sport Trac, not V8)
I actually got mine for $25~ shipped they come and go on EBAY, but you have to make sure the piping is as shown in my final product.
Here is an auction now, a little bit more expensive, but if you want to try it out, here it is
http://cgi.ebay.com/ebaymotors/BCP-02-03-F...d=p4506.c0.m245
For reference just in case the ebay auction goes down.. here is the picture of the Explorer kit..
Unfortunately the filter adapter to the MAF that comes with the Explorer kit will not work. You will need the ones made for Mitsubishi's. It doesn't have to be labeled for the Montero. The most common easy to find is the one for the 2G DSM turbos (95-99 Mitsubishi Eclipse GSX/GST, Talon TSi) Here is the cheapest one currently going on eBAY
http://cgi.ebay.com/ebaymotors/95-99-ECLIP...sQ5fAccessories
this will work as well
It's more expensive however, but does offer bigger diameter opening.
For reference..
So getting the Explorer intake kit above and the cheaper filter/intake is about $80. AGain it can be much much cheaper. You can buy the Mitsu MAF/MAS adapter without the filter for $10 shipped
http://cgi.ebay.com/02-05-Mits-Lancer-Mass...id=p3286.c0.m14
And you can sell the MAF adapter and filter that came with the Explorer kit. And if you are asking why you can't use the filter that came with the explorer kit, the ID" is just way too big for the MAF adapter of the mitsubishi. If you get the more expensive one I also showed above it will fit, but that already comes with it's own filter.
Then just go to Home Depot and get a brass fitting for the vacuum line so you can extend it to the nipple on the new filter. It's about $2
Put it all together and your set. If you watch the auctions you can maybe get away in getting this all done for $50.
Optional things to do is make a bracket.
So the big question, any difference?
Throttle response is much better. Power wise I felt it gave it some kick. Obviously no officially data, but the difference is there and can be felt. For as cheap as I got it, why not.
Old Aug 17, 2009 | 12:36 PM
jason clipse's Avatar
thats pretty cool
Old Sep 28, 2011 | 06:27 PM
shankadank's Avatar
Do you know if I could do the same thing with a cold air intake?
Old Sep 28, 2011 | 09:07 PM
Mr. Z.'s Avatar
I love to see nice mods. for under a hundred dollars! Well done.
The only reason I have not gone the same route is a concern regarding water crossings. Although, I don't do enough deep crossing to demand a snorkel, I'd be a bit worried having the filter so exposed in the engine bay. Water that does get flushed into the OEM intake drains fairly well right before the air box. This summer in Colorado I found that it can drain quite a bit, without even getting the air filter wet.
Have you thought of headers and a free flow exhaust?
Old Nov 28, 2013 | 12:02 PM
woodly1069's Avatar
I know this post is kinda old but does anyone make a turbo kit for the Montero? Seems like it would fit right there on the passenger side
Old May 4, 2014 | 06:31 AM
wishinforfishin's Avatar
Default Air intake adapter for 2.4L
I took a shot on an adapter and found it to be a perfect fit with 2 minutes of sanding to clear a couple of screws. Mounts directly onto the stock intake.
Spectre #81403 I bought mine on line $12.00 free shipping. Took 10 min.to install just had to buy nuts and bolts at the hardware store. A 4" cone filter fits right on it.
Old Jun 10, 2014 | 03:29 PM
i since then removed the system, because im in CA, and just tired of having to remove it each time for smog.
If anyone is interested in purchasing this from me. I will include everything you see. for $50 shipped OBO. no po boxes, only within the USA. Via paypal
just send me a private message
Old Jun 10, 2014 | 08:35 PM
Nice job on the mod. Two questions:
1. Did you notice any difference in the performance? I imagine it is your "daily driver" so the performance is a relative thing.
2. How come you have to change back every time for smog testing? Did the car not pass the smog test with the mod on it or is it a California requirement to have unmodified air intake system? Forgive my ignorance of this - they don't do the smog tests in the are where I live.
Old Jul 6, 2014 | 03:02 AM
lol its hard to really say performance because i never dynoed it.
i can only go with what i think. the throttle response felt better. you hear that intake noise when you blip the throttle.
as for performance, i "felt" it to improve, but like drastic OMG push you in the back of your seat gains??---nope
i once ran into an 03-06 Montero, which i believe has a higher HP engine, and i actually pulled on it when we had a quick race. but who knows if the driver didnt know how to drive.
and yes SMOG is a hassle here in CA if you have mods. even if you pass the actual testing, if you have parts that are aftermarket, no carb stff, etc. you fail. but i have passed the actual testing with it, its just the visual i didnt
redturboeclipse
22
Jun 22, 2020 06:35 AM
redturboeclipse
Apr 27, 2014 11:45 AM
apw5060
Sep 23, 2011 08:00 PM
redturboeclipse
Mar 14, 2010 05:23 PM
kniel023
Dec 28, 2006 12:51 AM
