Fault code help
Old Aug 21, 2024 | 01:07 AM
Agm4495's Avatar
Default Fault code help
Hey everyone I just bought a 95 montero 3.0 and to say the least I'm pretty new to this brand and engine. My montero has been running rough on cold start so I decided to pull codes and only got 11.
Ive seen posts say its a o2 sensor, others say things like missfire, not enough fuel or restriction, and tps.
Could use advise and input on what call did to fix or what yall recommend i do next. Thanks!!
Old Sep 3, 2024 | 12:52 AM
Mistress_Rachel's Avatar
How did you pull the codes? 11 is O2 sensor. see if you can figure out which one it is? I don't remember if the engine has 1 or 2? If there are 2, unplug one and see if the issue changes. If it doesn't, that's the one to replace. If there is only one sensor, replace that one.
shownuff80
Aug 26, 2019 11:39 PM
PalmSprings
13
Dec 3, 2017 02:29 PM
2001Mitch3.5XS
Jan 5, 2015 03:38 AM
frogfamily5
Aug 6, 2009 09:17 PM
dsiglin
Mar 29, 2008 12:37 AM
