FYI on Toyota wheels compatibility to Montero SR
Old Nov 16, 2014 | 08:53 PM
iworkalone's Avatar
Default FYI on Toyota wheels compatibility to Montero SR
Just wanted to throw this out there, I was recently offered (4) wheels with mint Michelin tires on them plus spare for $500. Problem was my 1996 montero sr had 15's. The hole pattern matches but the mitsubishi hubs are a bit too large. Problem solved this way; purchased a 4 1/4" Milwaukee hole saw from home depot (lowes does NOT carry 4 1/4"!). Just bore out the center hole from the inside as there is a nice chamfer there allowing the hole saw to self center. The wheel center's on the studs not the center hole so no need to be super accurate. The only problem you will encounter is the center caps don't fit. The rear ones do but not the front ones. Make sure you bore slowly, use a lubricant.
Good luck
Old Nov 17, 2014 | 10:57 AM
user 27474884's Avatar
Good luck
Sounds sweet!
Pics or it didnt happen lol!
Old Nov 25, 2014 | 12:59 PM
shownuff80's Avatar
Hummer H3 16" wheels fit our gen monteros aswell i believe.
Old Nov 27, 2014 | 11:59 AM
Akzle's Avatar
good job eh.
Course, id just chuck em in a lathe...
jpmontero98
Aug 31, 2007 02:20 PM
montero91
Feb 26, 2007 12:37 AM
dirtwagon
Jul 25, 2006 11:46 PM
BurntGSX
Jan 5, 2005 07:56 PM
Eclipse_GSX
Dec 9, 2003 05:27 PM
