harmonic balancer gets loose
Old Jul 21, 2015 | 06:31 PM
Harvey32's Avatar
Default harmonic balancer gets loose
3.5L engine the bolt that holds the harmonic balancer falls out how can I fix this, it has the correct torque any suggestions
Thanks
Old Jul 22, 2015 | 06:24 PM
It shouldn't do it if its torqued to correct spec. After you tension the bolt, does harmonic balancer seats properly and firmly or is is loose and wobbly? It is possible that you have mangled up thread ether on the bolt or the female thread on the crankshaft. With the help of a small mirror check the internal threads to see if something is stuck in there preventing bolt from full engagement. Clean and degrease mating surfaces on the pulley and the crankshaft. You need to lightly oil the bolt threads. Make sure you don't forget the washer between the bolt and the dampener. I believe the correct torque is 137 ft-lbs. That is a heck of a lot.
deziking
Aug 29, 2019 12:04 AM
Harvey32
Jul 21, 2015 10:27 PM
Lobosmom1
Sep 5, 2012 02:08 PM
cptkid570
Dec 14, 2005 12:59 PM
Timmay
Sep 26, 2005 06:15 AM
