HELP 94 Montero LS died on the highway
Old Nov 23, 2009 | 07:04 PM
mikewired's Avatar
Default HELP 94 Montero LS died on the highway
My nephew was driving when it died. I arrived to check out the Montero, and I first noticed that while trying to get it started, it sounded as if the starter was not engaging and turning over the engine. I opened the hood and noticed that the starter was in fact turning over the motor but no resistance. I took off the timing belt inspection cover and the belt is not broken. It appears that their is no compression on any cylinder? I did use a compression tester on just one cylinder and 0 compression. What do you guys think, jumped time? I can't even conceive that all of the connecting rods are broken. Could it have over heated so badly that all the rings are toast? Holes in the pistons from hitting the valves? I also did discover that there was no water showing in the radiator, but the overflow was full.
Old Nov 23, 2009 | 08:19 PM
dsm1990gsx's Avatar
How many miles are on it? It sounds like the belt either jumped timing or it stripped the teeth off the timing belt.
Old Nov 23, 2009 | 11:10 PM
mikewired's Avatar
It has 228,000 give or take a few, the belt was replaced somewhere around 140k
bronzebogen
13
Apr 16, 2015 07:32 AM
frankv
Mar 14, 2013 07:51 AM
baumer
Jul 5, 2010 02:27 PM
Thewoodieb
Dec 7, 2009 11:51 AM
EMonz57
May 4, 2006 01:14 PM
