Help with EGR Solenoid for 1996 Montero SR
Hi,
Anyone have any ideas where i might be able to locate a replacement EGR solenoid for a 1996 Montero SR 3.5L DOHC? I've searched high and low, and online parts store keep pointing to part #MR188756 which does not fit. Some have even pointed to the wrong part as they don't differentiate between sport and non sport version. I compared the part mentioned above to what's in the manual and just by looking at the connector alone, the part mentioned above would not fit. Also checked it on my Montero, and yeah there's no way MR188756 would fit. :confused: Hoping someone could help shed some light and maybe point me in the right direction. Thanks, -Tom |
Have you tried to call a Mitsubishi dealer and having them look up a part number by your Montero's VIN? I had a situation like that with the oil coolant hoses some time ago. The parts listed were not even close to what I needed, but local dealer was able to properly ID necessary part numbers.
EGR solenoid
I just replaced on my 02 montero. It's called EGR control valve solenoid. If this post is not too late, you can easily order any part online at Rockauto.com and not pay dealer prices ever again. Well, unless is a dealer only item. Let me tell you, when I replaced it, I thought that was the problem because I had low EGR flow pressure. But it turns out it was a port that was plugged on the intake (there abouts on the butterfly assembly ) Hope my post help you and many others
Also have a '96 Montero SR. The valve that every website says will work (VS127) won't fit. None of the other ones that I've found have the correct connector. I can't even make heads or tails of the parts websites, as there seems to be legit confusion as to what goes onto the 96 SR.
Did you ever find a resolution to this? Rockauto is wrong, amazon is wrong.. etc. |
EGR solenoid problem
Originally Posted by MNalfa
(Post 320724)
EGR solenoid
Originally Posted by Astromam
(Post 320735)
Well, I have had my share of incorrect parts from Rock Auto but I have an 02 Montero and must be very different than yours. Since you are having so many issues, are you sure it's a bad valve, cause if it's broken, you could JB weld it. And if it is bad then you should take a photo of the egr plug and tell a Dealer parts rep, that you would like to send him the "pic", along with your vin # to be certain you get the correct part and once you have a part # , you can shop around online. Cause a few Dealers have different prices . Well let me know if I can help any further.
And supposedly part # 911850 Fits monteros from 1997-02. This is the part I got myself and fits many mitsubishi. I would suggest to look for this # at rockauto just to figure out if it's the same you got. They have a 3D picture and it's a 2 prong plug . Hope this helps |
Hi Astromam, thanks for the reply. I removed the solenoid causing the code (p0403) and I have a sinking feeling that its a california special thats no longer available. The solenoid you linked me to is the EGR Purge solenoids, but my rig has EGR 2 solenoids.
The one I'm looking for has k5t49586 stamped on the side of it. This translates to mr127232, which I can't find anywhere. Apparently, my dealership ordered the "Purge solenoid which has the wrong connector and mount. the search continues... it looks like this.. http://www.dhresource.com/0x0s/f2-al...3-3000-egr.jpg |
[QUOTE=MNalfa;320744]Hi Astromam, thanks for the reply. I removed the solenoid causing the code (p0403) and I have a sinking feeling that its a california special thats no longer available. The solenoid you linked me to is the EGR Purge solenoids, but my rig has EGR 2 solenoids.
The one I'm looking for has k5t49586 stamped on the side of it. This translates to mr127232, which I can't find anywhere. Apparently, my dealership ordered the "Purge solenoid which has the wrong connector and moun the search continues... it looks like this.. http://www.dhresource.com/0x0s/f2-al...3-3000-egr.jpg Just covering all the bases. Have you checked if you have voltage and ground on the plug, cause if you don't you might replace a good solenoid that has an electrical issue. You can ck with a cheap test light. If this is the case, you won't need the part. Try with ignition "on" to see which is what (pos or grd) |
Just throwing this idea out there - what if you take a different solenoid and change the harness connector to make it fit the new style? I realize it is risky, but how about making an adapter to go from the old harness to new solenoid?
EGR Solenoid problem
Originally Posted by HunterD
(Post 320747)
