Help with wiring
Old Mar 30, 2015 | 08:12 PM
charlesdds's Avatar
Default Help with wiring
I have a 1991 Montero RS- it did not come with an aux instrument pod(volts/inclimeter/oil pressure), I purchased one and read that it is plug and play. I have removed the vent cover and I only see this wire bundle, but I do not know if this is the harness I am looking for or a wire bundle for other things. I cannot pull it out easily(either attached to other parts of the dash/console or the plastic connector is wedged)
Does this look like the right thing? I do not want to pull hard and disconnect something I shouldn't. Is it possible that this truck isn't pre-wired???
Any help would deb greatly appreciated.
Thanks,
chuck
Old Mar 31, 2015 | 08:25 AM
charlesdds's Avatar
bump it
Old Apr 1, 2015 | 12:19 PM
Akzle's Avatar
possible? Id say its probable. You may not even have the correct sensors.
If its that 'difficult', youre probably not up to it.
Get handy with wire cutters and a soldering iron.
Old Apr 1, 2015 | 01:18 PM
charlesdds's Avatar
yes- I have the correct sensor for the oil pressure(just need to change it out)
Chuck
Old Apr 4, 2015 | 06:41 PM
charlesdds's Avatar
Success!!
Afetre removing a lot of underdog ductwork- i was able to get ahold of the wire and connector--- bingo! it was the harness for the aux gauge pod!
Thanks for all the input!
BruceWayne
Apr 8, 2010 10:48 AM
devono
Mar 2, 2006 12:53 AM
hambony
Apr 22, 2005 12:10 AM
slrine2000
Jun 7, 2004 10:47 PM
