hi all, I need your help
Old Mar 12, 2014 | 03:20 PM
achiiiiiiiiii's Avatar
Default hi all, I need your help
1. i have mitsubishi montero limited 2002, it has some detonation, wrote service engine soon, when i checked there was ritten problem - poor mixture in the bank 1 and bank 2 - do you know what does it mean? and what should i do to repair the detonation.
2. what is the difference between mitsubishi montero limited 2002 dohc and the same sohc?
Old Mar 12, 2014 | 09:39 PM
Default What are the codes?
What actual codes you get from your Montero? P###?
As for part 2 of your question - DOHC = Double over head cam, SOHC = Single over head cam. These are different engine configurations, which means that some parts will be specific to particular engine.
Old Mar 12, 2014 | 11:09 PM
Akzle's Avatar
Originally Posted by achiiiiiiiiii
what does it mean?
either the fuel or computer is crap.
My money is on computer. (sensor)
Old Mar 13, 2014 | 03:59 AM
Thank you, the service manager did not tell me the codes, he said that there was written: poor mixture in the both banks an it wold be air problem in engine, but he could not tell me what is it.
Old Mar 13, 2014 | 04:56 AM
so, means twin bank modified engine is ,, dohc ``? is it so?
Old Mar 13, 2014 | 10:14 PM
Akzle's Avatar
twin bank means v engine.
Old Mar 14, 2014 | 12:12 AM
so, will it be same spark plug wires for sohc and dohc? or it will be different?
Old Mar 14, 2014 | 02:04 PM
Akzle's Avatar
take your vehicle to a man that knows things.
Old Mar 15, 2014 | 05:25 PM
greg409's Avatar
achiiiii, you are asking what something is - without knowing what you're asking for.
We don't know where to start without knowing the code numbers, since we're not driving your truck.
Having said that, dohc,sohc, have nothing to do with poor mixture.
spark plug wires probably have nothing to do with it either.
If I were pushed, my guess would be dirty Mass air flow sensor (depending on the code numbers) it can be cleaned easily in 5min. (by someone who knows what they're doing)
maybe oxygen sensors (again code numbers)
detonation generally is caused by running really hot or really lean mixture
Do you know if anyone maintained the truck or was it run until it broke?
I agree, take it to a mechanic who's not afraid to give you detailed information
luck,greg
Driver99
Feb 25, 2008 02:16 AM
Patrick
Aug 23, 2006 06:20 PM
Patrick
Jun 1, 2006 09:05 PM
stephmar
Jun 29, 2005 05:55 PM
puffy
Jun 7, 2004 05:16 PM
