How to: Remove lower timing gear
Old Apr 29, 2013 | 08:27 PM
Justin C.'s Avatar
Default How to: Remove lower timing gear
Can anyone tell me how to Remove a lower timing gear. The shear pin is...well, sheared. I need to replace the Demonic balancer and I noticed that the pin is sheared off. The engine or crank shaft doesn't have to be pulled right? Are there any special tools needed? Is it possible to replace just the roll/shear pin, if so how?
97 Montero LS 3.5l
Please and thank you!
Attached Thumbnails How to: Remove lower timing gear-2013-04-21-18.jpg
Old Apr 30, 2013 | 06:57 AM
If the bolt is into the crank, you'll have to take it out to fix the sheared key way.
Old Apr 30, 2013 | 09:35 AM
mxmikie's Avatar
2 jaw puller
Old May 1, 2013 | 02:13 PM
I doubt you'll get that in that space.
deadreckoning86
May 27, 2014 01:46 PM
2k1monterosport
May 16, 2011 12:26 AM
dsm1990gsx
Aug 5, 2008 12:59 PM
jrevelle
Sep 16, 2007 08:24 PM
grn97GS
Sep 27, 2005 12:57 AM
