Instruments illumination lights doesn't work (cluster, cigarrete...)
Old Sep 15, 2019 | 08:12 PM
Jozelitox's Avatar
Default Instruments illumination lights doesn't work (cluster, cigarrete...)
Hello!
I have a Montero 3.2 DID and I have a problem with the interior dash lights (cluster, cigarrete, a/c....), yesterday I'm checking for rear fog lamp fault (doesn't work), removing/installing somes fuses to check if was ok, the rear fog lamp start to work, but now (I think that I put in contact the two pins from illumination in the rear fog connector button with the multimeter checking for the rear fog lamp fault) the instruments illumination lights doesn't work, in the cluster the white light not are illuminated, the acc white light also, in cigarrete, ashtry...
I don't know what's the fuse for ilumination lights and from where comes the positive to check the relay... someone have the system wiring diagrams? Someone know more info about this?
Thanks for the help!!!!
JosMitsubishiLover
Feb 9, 2017 12:07 PM
Winter139
Jul 20, 2011 03:00 PM
nocar39
May 27, 2008 02:14 PM
bcolins
Jan 31, 2005 02:58 PM
gi
Dec 29, 2004 05:47 PM
