lifter noise
Old Oct 21, 2019 | 12:54 PM
kc2llw's Avatar
Default lifter noise
Hello,
I have been working with Larry offline on my head gasket repair. Now I seem to have a lifter noise. I have attached a video of the engine running.
Thanks,
Steve
Old Oct 21, 2019 | 04:54 PM
larry4406's Avatar
Steve - I don't think your video loaded, try again.
Here is a link to the bleeding procedure for the valve lash adjusters to remove air and quite them down.
https://mitsubishiforum.com/forum/mi...e-50883/page2/
-larry
Old Oct 21, 2019 | 05:08 PM
kc2llw's Avatar
-larry
Larry,
I am getting this error message:
Alert
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
Old Oct 21, 2019 | 05:17 PM
larry4406's Avatar
Originally Posted by kc2llw
Larry,
Alert
I think that’s geek speak for “your attached file is too big”. I’ve had that before.
Old Oct 21, 2019 | 07:27 PM
kc2llw's Avatar
Yeah, I guess I can take a shorter video and try tomorrow. thanks for the bleeding link I will try that this week too.
Old Oct 21, 2019 | 08:11 PM
kc2llw's Avatar
here is a edited version
File Type: mov
Old Oct 22, 2019 | 04:28 AM
larry4406's Avatar
Wondering if its your hydraulic belt tensioner? The frequency of your "ticking" sounds too fast for lifter noise (VLA) at idle to me based on how mine ticks. Either that or you have several ticking.
Checkout this thread and Post 7 in particular.
https://mitsubishiforum.com/forum/mi...failure-49571/
Similar:
Old Oct 22, 2019 | 08:15 AM
kc2llw's Avatar
Larry,
You are saying it may be the hydraulic timing belt tensioner or the serpentine belt tensioner. I installed a new water pump timing belt, idler as well as a new timing tensioner. The serpentine belt and serpentine tensioner were not replaced.
Thanks,
Steve
Old Oct 22, 2019 | 10:25 AM
larry4406's Avatar
The video links I found were of failed hydraulic timing tensioners.
Old Oct 22, 2019 | 11:03 AM
kc2llw's Avatar
I guess the failed tensioner makes the timing belt loose and a slapping noise. I did install a new tensioner and followed the install procedure also check the gap which I was around 4.2mm. I just ran it again and it is hard to determine where it is coming from.
