Lifting a 97' LS
Old Jul 23, 2006 | 10:49 PM
Andyfoos1's Avatar
Default Lifting a 97' LS
I have a 1997 Montero LS with the 3.5 motor. I love this truck, but i am a little disappointed with the stock ground clearance. I am going to put on a little larger tires than stock, i don't want to go much bigger than 31's or maybe 33's, gas milage purposes, but i want to gain a little more. Does anybody have any idea of a reasonable lift kit or some type of trick to raise my Monty?
Old Jul 27, 2006 | 06:47 PM
off roader's Avatar
Default RE: Lifting a 97' LS
31's will fit stock! No lift required.
33's will require a torsion bar crank and possibly (not 100% sure) and 1" coil spacer in back or a longer coil. You'll also need to replace the wheels and use one with a offset that brings the wheels out farther from the body for a wider stance to get the necessary clearance (when turning left or right).
Alternatively you can also do a body lift.
One other thing, 33's will affect the performance and gas mileage since you'll effectively be geared higher (loosing torque, etc.) IIRC, they do have 4.88 R&P gears (mitsu only) but don't quote me on that.
IF you really want to go big, do a 3" lift and put 35's underneath. You'll definitely want to get new R&P's though and possibly upgrade your xcase gear to a 2.89 ratio gears available through "Misterbishi" in Australia.
For those that have the 3.5DOHC engines (94-96 SR's) then 4.90 R&P's defitely exist as well as 3.51 xcase gears gears.
HTH.
Myowncreation
Jan 25, 2013 10:22 AM
amiel
Sep 6, 2010 07:01 PM
Locky
Jun 4, 2007 02:08 PM
Andyfoos1
Oct 24, 2005 11:25 PM
