Might be getting a 2006 montero.. questions
Old Oct 9, 2013 | 03:17 PM
outnabout's Avatar
Default Might be getting a 2006 montero.. questions
Hey,
I have an outlander right now and I need something bigger and that can go off road.
I am thinking about getting a 2006 montero. I found one with under 50k miles on it ()
Questions:
1. how often is the timing belt needs to be changed? cost of doing so at a shop?
2. I read somewhere that you can put 33-32s (tires) on a stock montero - is that true?
3. Any known issues I should check?
4. Is it possible to open the rear window? (by rear I mean the one on the trunk's door)
Thanks!
Old Oct 10, 2013 | 07:12 PM
navidbe's Avatar
no you cant open the rear window
check and see if the service was done by the dealer!!!!!!!!!!
for the belt and stuff thats a usual service that costs a few hundred.
for the tires as long as it does not rub is should be fine, but make sure you have enough room when you want to go on rocks and stuff.
BenWA
Jul 29, 2015 08:43 PM
davidmitsusrock
Aug 29, 2007 11:45 AM
jstylez
Apr 23, 2007 09:54 AM
Lil Evo
1st Generation
Mar 21, 2007 01:49 PM
xXxIZZYxXx
Aug 15, 2006 09:03 PM
