Mitsubishi nativa 2003
Hi ,
i have 2003 Mitsubishi nativa and my problem is it cranks and starts when i spray fuel in the throttle body but dies after few seconds, i changed the fuel pump and the fuel filter my fuel pressure is good too but my MAF sensor is bad i need help
If the fuel pressure at the engine is good, then it sounds like the injectors are not firing. It can be related to cam or crank position sensor. It should run even without MAF sensor (in open loop mode).
tonileila
Dec 19, 2014 06:56 AM
