Mitsubishi nativa 2003
Old Nov 4, 2021 | 09:11 AM
Hamood's Avatar
Default Mitsubishi nativa 2003
Hi ,
i have 2003 Mitsubishi nativa and my problem is it cranks and starts when i spray fuel in the throttle body but dies after few seconds, i changed the fuel pump and the fuel filter my fuel pressure is good too but my MAF sensor is bad i need help
Old Nov 4, 2021 | 12:49 PM
If the fuel pressure at the engine is good, then it sounds like the injectors are not firing. It can be related to cam or crank position sensor. It should run even without MAF sensor (in open loop mode).
Old Nov 7, 2021 | 09:36 AM
Hamood's Avatar
Thanks a lot it was the injectors they were clogged very badly it started after cleaning them after cranking and priming the fuel pump it fired right away
Old Nov 7, 2021 | 10:41 AM
Awesome. Thank you for following up on your progress. Glad you got it runing.
Old Nov 8, 2021 | 08:12 AM
Hamood's Avatar
All thanks to you #hunterD
Scotsoutlander
Dec 15, 2019 02:21 PM
ZillaG
Mar 19, 2016 04:20 PM
tonileila
Dec 19, 2014 06:56 AM
freddie
Aug 29, 2011 01:25 AM
ryan51173
Jan 10, 2011 06:16 PM
