Mitsubishi nativa / montero 4wd keeps flashing
Old Jan 16, 2018 | 11:32 AM
C0000lguy's Avatar
Default Mitsubishi nativa / montero 4wd keeps flashing
Hi guys
i have mitsubishi nativa / montero 2006 3.0L with normal 4x4 gear (2h,4h and 4L)
Which works very fine
but
when i shift to 4H or 4L the light keeps blinking..
And it says same until i shift back to 2H
any solution? ???????
Old Feb 1, 2018 | 04:17 AM
iamgee's Avatar
Hey, sorry i cant help, but I have a 2008 model with the same problem and looking for the solution as well. But it is not just about blinking, my car does not switch back to 2H. The differential lock is always on, in any case, and keeps on 4WH. I'm afraid it is a transmission issue.
Old Feb 1, 2018 | 09:28 PM
sapu1967's Avatar
Hi I have a 2006 Mitsubishi Montero Jeep. After I drive about 20 - 40 km The CENTER DIFFERENTIAL LOCK LIGHT starts flashing yellow. This prevents being able to change 2 to 4 wheel drive. After the car is turned off and restarted the light goes back to normal. I've preformed all the transmission service, flushes etc. My mechanic says I need to replace the 4 or 5 sensors on the transfer case. But isn't 100% sure if this will fix the problem or not. The car has 120,000 km on it. PLEASE HELP WITH ANY SUGGESTIONS ON THE FLASHING LIGHT
Old Feb 2, 2018 | 12:18 AM
The issue with the flashing center differential light is not related to transmission. It is an issue with the transfer case (which is bolted to the back of transmission). Servicing transmission will not solve those issues. Most often the problem is with the sensors not reporting correctly to the transmission/transfer control module. The module "detects" a mismatch of the data coming in vs. what it is expecting and throws out the warning - flashing orange light. It could be just single bad sensor (out of 5) but it may be difficult to pin point which one has gone bad. A mechanic should be able to pull the error codes from the transfer ECU (just as you do with Check Engine Codes). The code will tell which of the sensors is malfunctioning. If they do not have tools to connect to transfer ECU, there is a way to ground a pin on the computer interface plug and make the orange light flash out the pattern to indicate the error code.
wajira
Nov 13, 2015 04:34 AM
montyman
11
Jul 30, 2013 11:03 PM
olijayp
Aug 6, 2012 02:53 PM
joeuspe
Aug 12, 2011 07:42 PM
capricorn1
Jul 21, 2011 07:28 PM
