Montero Ignition Problem
Old Jan 22, 2007 | 10:34 AM
czabala's Avatar
Default Montero Ignition Problem
I have a 1995 Montero SR 3.5L, 87000 Km (54000 miles). Since 8 months ago I have a ignition problem, when the car is getting hot the engine lose power and begins to stall because 1 of the 3 coils doesn't receive signal from the power transistor and the 2 cylinders attached to it doesn’t work. I have changed 3 times the power transistor but after 4000 km (2500 miles) approximately it fails again. I changed a new set of wires, spark plugs, even the coil that doesn't receive signal but the power transistor still fails after a while. The last time I took the car to the official technical service but they just changed the power transistor and told me that everything is ok. I don't know what else to do. If someone has an idea what the problem could be, please tell me.
Old Jan 24, 2007 | 03:29 PM
Winshawn's Avatar
Default RE: Montero Ignition Problem
Change the coil.
Old Jan 26, 2007 | 06:59 PM
mxmikie's Avatar
smell your ecm (fishy smell) sounds like the caps are leaking you can open the ecm and check (black tar) for leaks after time it will destroy the printed circut board
allallyouyou
Feb 12, 2012 11:13 PM
bassmankws
Feb 1, 2008 11:35 PM
copperboard
Apr 17, 2006 11:04 PM
copperboard
Apr 5, 2006 10:23 AM
pilot
Jan 14, 2006 10:42 PM
