Montero SR pulling to the right
Old Jan 6, 2012 | 10:51 PM
Liston's Avatar
Default Montero SR pulling to the right
My 95 SR has always seemed to be pulling to the right slightly. I have tried a bunch of stuff and it happens no matter what. I thought the new tires and alignment would do it, but no dice.
I have had 2 different sets of wheels and tires on it and no matter the arrangement, she pulls right. I got new tires (33 x 10.5, love them) on the factory 15 x 7's , then torsion crank and the alignment done (camber and tow)...still pulling right.
Old Jan 7, 2012 | 05:15 AM
mxmikie's Avatar
brakes ?????
Old Jan 7, 2012 | 10:05 PM
Liston's Avatar
Rotors are in good shape, I got the front and rear brake pads changed right after I got the truck. Pulling before the swap, pulled after. It pulls regardless if I am on or off the brakes. Braking does not make it change.
Old Jan 8, 2012 | 07:17 PM
mxmikie's Avatar
it will if the calipers have jelled brake fluid in them
Old Jan 9, 2012 | 03:40 PM
new_kid's Avatar
Have you checked your linkages for wear.. or tire pressure..etc.
Are the tire patterns same for both front tires?
I would suggest if all above is ok, then do a complete bleed of the brake system.
Old Jan 10, 2012 | 08:35 AM
Liston's Avatar
Linkages look good, I've tried all different tire pressure combos, always pulls right, unless I seriously underinflate the front left tire lol. The tires are brand new bf at ko's all around. I'm going to try the brake bleed, good idea.
Old Feb 19, 2012 | 12:58 AM
Liston's Avatar
Default No difference - Brake flush, tire balance, alignment, rotation
Ok so I am pretty friendly with the tire shop where I got my new tires and told them about my pulling problem. I had them flush the brake lines while there.... which made my pedal feel better but the truck was still pulling to the right. They rebalanced all 4 tires for me and checked the alignment (still good). I suggested a radial pull (for S & G's), so they tried a right to left rotation.....still pulls right.
Old Mar 18, 2012 | 07:53 AM
Liston's Avatar
Anybody have any other suggestions?
Just to review what I've done:
4 brand new bf goodrich a/t tires balanced with pressures ok - left to right swap=no change, alignment checked twice, new brake fluid, rotors & pads in good shape, new Mitsu fluids in diff's and transfer case.
What should I try next?
Old Mar 27, 2012 | 01:00 PM
masterg's Avatar
what if the suspension / air shocks for that tire are failing?
mitsulanceroz
May 28, 2013 06:09 PM
relayer77
Feb 3, 2012 09:01 PM
cptkid570
Dec 14, 2005 12:59 PM
avshockey
Jul 21, 2005 06:43 PM
carcarnotjarjar
May 2, 2004 01:08 PM
