Pulling steering wheel in '95 Montero SR
Old Oct 12, 2011 | 12:16 PM
relayer77's Avatar
Default Pulling steering wheel in '95 Montero SR
Hello,
This is my first tech post, I've searched thoroughly and haven't found any post related to my problems, apologies in advance if I missed it.
I'm having a hard time pulling my steering wheel on the '95 Montero. I have removed the air bag and the steering wheel nut, and when I attached the steering wheel puller, it seemed to fit perfectly with the bolts I chose. I marked the steering wheel and tightened down, but the steering wheel won't budge. I checked out some videos on youtube that showed how to remove steering wheels on other makes and models, and the folks demonstrating didn't use near as much torque as I have, but it' s not working. I'm going to chase down a Chilton's, I suspect that there is some step I'm missing that is specific to this model. Thanks for any tips!
Old Feb 3, 2012 | 01:54 PM
half ton's Avatar
I too am wanting to replace the combination switch...the right turn signal often will not engage without holding it.
So did you get your steering wheel off? Was there a secret or was it just stuck? BTW, how much and where did you get the new switch?
Thanks,
Half Ton
Old Feb 3, 2012 | 09:00 PM
mxmikie's Avatar
Thanks,
Half Ton
you can change this switch without removing the wheel just remove the trim
Old Feb 3, 2012 | 09:01 PM
mxmikie's Avatar
Originally Posted by relayer77
Hello,
i have seen them take up to 60ft lbs of torque to get the wheel off
Liston
Mar 27, 2012 01:00 PM
joepesch
Jun 10, 2010 03:28 PM
runner45
Oct 16, 2008 09:34 PM
BEAT
Jul 28, 2008 12:25 PM
ken lally
May 9, 2007 01:27 PM
