Monty Ltd won't engage drive
Old Mar 28, 2015 | 03:07 PM
lovinmrv's Avatar
Default Monty Ltd won't engage drive
Hi all,
I have done some searches in here for this issue, but have yet to find anything that answers my question....so here goes...
I have a 2001 Monty Ltd with 199, 250 miles. I cannot engage drive. Park, neutral, reverse all work, but i can't get it to drop into drive. I have seen two basic solutions in here.....flush the transmission or get a new transmission range sensor. Might there be some adjustment i can make in the linkage? It appears that there is some play in there....can I tighten the shift cable?
Thanks in advance...
gc
Old Mar 28, 2015 | 07:40 PM
Akzle's Avatar
cable? Thatd be a new one on me.
Get into it and find out.
Old Mar 30, 2015 | 01:06 AM
There is no cable on transmission shifter on the 2001 Montero Limited.
Check the transmission switch operation. Look up the FSM on one of the Sticky posts on the Montero Forum (the 2003 year will do) and check the shifter operation and the switch contacts engagement. FSM has all the instructions for it. I hope that is where your problem may be.
Old Feb 19, 2018 | 11:48 AM
reznor's Avatar
Hi all,
gc
Hello lovinmrv did you ever have the solution for this problem on the montero? Im having the same issue and believe me Im walking Egypt right know. Don't know what to do anymore. hoping you ever got a solution and can give me some light . thanks for your time and have a nice day
lovinmrv
Sep 25, 2016 12:12 PM
Fonz11
Oct 20, 2014 04:44 PM
sn22
Apr 9, 2011 09:31 AM
myersbr2
15
Nov 8, 2010 01:49 PM
rbhylland
Jan 2, 2008 09:55 PM
