!!!!NEED HELP FAST!!!!!
Old Nov 26, 2008 | 02:31 PM
2001 Mitsubishi Mont's Avatar
Default !!!!NEED HELP FAST!!!!!
Recently did the oil change on my 2001 montero and when i went to turn it on it turned on fine and everything... then iheard a diesel type noise i hear it coming out of thevalve covers... thought it was the synthetic oil that was too thick so iputsome regular 10w 30 oil... well nothing the noise was still there,next step i took wasireplaced the oil pump and still nothing..has anyone everencountered this type of problem... thanks in advanced
Old Nov 26, 2008 | 04:09 PM
carlover626's Avatar
Default RE: !!!!NEED HELP FAST!!!!!
There is a oil pressure sender, did you replace that with thepump? I wouldn't run it anymore until you verify oil pressure.
These may help you:
http://www.4x4wire.com/forums/showfl...ev=#Post526880
http://www.4x4wire.com/forums/showfl...art=1&vc=1
Old Nov 26, 2008 | 04:56 PM
now if theres no pressure the oil shouldnt come out the push rods right ... in mine it does i took off the valve cover cap and oil is coming up
Old Nov 26, 2008 | 10:03 PM
just got done installing the oil pressure sender it got rid of the diesel style noise but nowi hear a loud tapping noise.. thanks
Old Nov 27, 2008 | 09:55 AM
The tapping noise could be the lash adjusters. Whats the temperature where your located? I only use 10-30 in the summer, 5-30 in the winter...I was going to tell you to change the oil more often and see if that helps, but since it's new oil anyway...
What oil/filter comboare you using?
Old Nov 27, 2008 | 04:04 PM
the temperature here right now is 60 degrees.. the oil/filter combo i used was napa gold filter and napa oil.. also where is the lash adjuster.. i will try to get more oil to do another oil change on it.. thanks
Old Nov 30, 2008 | 11:26 AM
Check this out:
http://www.4x4wire.com/mitsubishi/te.../lifter_noise/
Old Nov 30, 2008 | 12:46 PM
oh okay i see when i did the oil change it was in my drive way which is kind of steep... also could it have been the synthetic oil that i put in the first time... sorry for all these questions
Old Dec 4, 2008 | 05:30 PM
SyntorX's Avatar
You replaced the oil pump? Did you do that yourself?
Wow.
Old Dec 6, 2008 | 09:51 PM
i did replace the oil pump and i did it my self... thanks
