Need Help!!! Please
Old Jun 22, 2013 | 09:39 PM
lharvill's Avatar
Exclamation Need Help!!! Please
my 1998 montero wont start, when i turn the key over all it does it click one time and thats it. i have tryed all day to figure this problem out, i had the alternator, battery, and starter, and starter soleniod checked out and all was good but the battery, which i replaced with a new one. but my montero is still only clicking once when i turn it over to try and start it, the engine does not try to turn or anything. i need help to figure out this problem. anyone??????
Old Jun 24, 2013 | 06:38 AM
Jeff Collision's Avatar
One common reason for a car not starting is that the battery is dead. If you turn the ignition and you hear a clicking noise, or you notice that the dashboard is not lighting up, your Montero's battery is likely dead. Since, you replaced the battery, check the battery terminals and connections and make sure that they are good. The absence of fuel could be the cause of a no-start engine. Put a few gallons of gas in the fuel tank. Inspect the fuel filter and the fuel pump. If either component is faulty, it could decrease the amount of gas sent to the engine. Look under the vehicle for fuel spots that could indicate a fuel leak. Finally, inspect the spark plugs. The spark plugs should appear clean. Make sure the spark plugs are securely connected with no worn tips. Test the spark plugs if they appear damaged.
enzo_hashmat2006
Oct 10, 2017 05:46 PM
BruceWayne
Apr 8, 2010 10:48 AM
thomas4g63
Nov 28, 2008 12:52 PM
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
