Oil leak - rear cam seal
Old Nov 24, 2014 | 02:18 PM
Media001's Avatar
Default Oil leak - rear cam seal
I've noticed an oil leak and it appears to be from the rear cam seal. From what I gathered on the internet, the o-ring needs to be replaced. Haven't really found any good information / instructions on how to do this. Appears to be fairly simple but not for sure. Guys on the internet says its a simple 15 minute job.
Have the gurus on here ever performed this before.
I have a 2003 Montero LTD.
Thanks in advance.
Old Nov 25, 2014 | 01:11 AM
This is a pretty simple procedure. It does help if you have small hands . Make sure the engine is completely cool, because you have to reach all the way around the engine bank right up to the firewall. The camshaft cover is held by just two bolts (don't remember the size). All you have to do it so remove the bolts and wiggle out the cover. The o-ring will come out with it. Replace o-ring, put a little oil on it before sliding the cover back on. Re-attach two bolts and you are done. Look for the manual on the sticky manual discussion thread near the top of the page. It will make it easier to know what you are looking for. Good luck
Old Nov 25, 2014 | 12:20 PM
Media001's Avatar
Thanks HunterD for your response. I will give it a shot.
Old Jan 1, 2015 | 12:29 PM
7-UP BILL's Avatar
How did the cam seal swap go? I need to do this on my '02.
Old Jan 1, 2015 | 02:27 PM
Hey 7-Up Bill, that seal is exactly where your cam position sensor is
Old Jan 2, 2015 | 03:28 PM
7-UP BILL's Avatar
Thanks, I figured while I'm doing the cam sensor I'll do the seals. Thanks. BTW the bolts for the cam seals are 12mm.
aps13
Jul 3, 2011 03:34 PM
TheRock0720
Nov 12, 2010 12:30 PM
wrkrbee
Oct 16, 2010 02:04 PM
mrvivona
Aug 12, 2009 12:57 AM
monterodude
Apr 27, 2005 09:52 PM
