P0154 Code
Hi Everyone,
I'm helping my friend repair a 2001 Montero Sport, and the check engine light code came back P0154. I see that others have commented on the TSB with the O2 sensor, but still have a few questions.
Are there multiple sensors on the vehicle....and which would do I need to replace? Is this a fairly easy repair (under an hour or so)? I've never done an O2 sensor before, and am trying to figure out if I'm able to pull this off.
Thanks for reading, and especially for any help provided!
I would like to know more about this update as well. We are having the same issue with our 2002 Sport and I have already replaced the front driver's side sensor once.
Does this update cost the consuer, or is itsupposed to be more of a recall issue?
ORIGINAL: lloydjv
that update is downloaded to your pcm from a dealer only. it takes about 30 minutes to do. the factory scanner plugs into your vehicle and downloads not only that information but any other updates that are available to that particular pcm. bank 2 sensor 1 is the upstream o2 sensor on the drivers side. good luck!!! greg...
callgauer
Aug 30, 2016 08:17 PM
Bnchs
Jul 7, 2006 03:29 AM
