Wheel Swap?
Old Apr 28, 2008 | 10:30 AM
jrmdir's Avatar
Default Wheel Swap?
Thanks in advance for help with this.......
Can factory wheels (16")from 2005 Montero Limited be used on a 1999 Montero (Full Size)?
Regards,
Ron
Old Apr 30, 2008 | 04:32 AM
lovinmrv's Avatar
Default RE: Wheel Swap?
Ron,
The bolt patterns are the same. You cannot use the 15s on a 2001 or newer because the calipers are too big. I do not understand why, however, you cannot use the 16s on an older Monty.
Old Apr 30, 2008 | 10:16 AM
Joel_CA's Avatar
ORIGINAL: jrmdir
Regards,
Ron
Nowont fit. Even though the bolt pattern is the same, he hub center bore on the wheel is smaller on the 3rd Generation Montero (2001-2005) than the 2nd Generation Montero you have (1999)- so the wheel won't fit over it. You can use the 15 or 16" wheels from any yearMontero Sport and it will fit right on your 1999Montero sincethe hub bore and bolt pattern are identical on the 2nd Generation Montero and the Montero Sport (of all years).
JJ
sk8dudety
May 31, 2014 08:55 AM
dr_max_facts
Feb 29, 2008 03:21 PM
chillinsb
4th Generation
11
May 31, 2007 03:15 AM
eclipse6racer
Dec 23, 2006 06:16 PM
trbodsm997
Dec 25, 2004 01:52 AM
