P0305
Old Oct 23, 2020 | 08:46 PM
Ramon97's Avatar
Default P0305
97 Montero Sport LS 3.0
Hello everybody, I’ve been having this trouble code for two years already and it’s been giving me a headache. I’ve changed spark plugs, plug wires, moved the injectors around, and even the coils. It’s a brand new motor and I have taken it to two mechanics so far. I’m guessing I have a vacuum leak somewhere but I don’t know where,i do notice the LTFT go down to zero when I’m driving and the STFT also get close to zero. I changed the intake manifold gaskets upper and lower. I would appreciate the help from anybody I also took a picture of the fuel trims at idle. I have a high idle since I replaced the gaskets, maybe I didn’t line it up right?
https://imgur.com/a/UulcXG2
Old Oct 24, 2020 | 10:51 AM
If 1,400 RPM is your idle speed, figure that one out before diving into fuel trims. Something went south there (I mean idle speed).
Old Oct 24, 2020 | 08:25 PM
Ramon97's Avatar
Thank you I kinda had the idea already about it lol. It used to idle at around 750 but I changed the upper and lower intake manifold gaskets Wednesday so I pretty sure I didn’t line it up correctly so will pull it off again and double check everything. Hopefully I can solve this problem
patreojames
Nov 27, 2014 01:02 AM
mark0514
Jan 1, 2014 05:36 PM
vince01
Oct 26, 2009 09:02 AM
wookey123
11
Aug 25, 2009 05:18 PM
