Problem with '00 MS-LS internal lighting
RE: Problem with '00 MS-LS internal lighting
Simple things first. Crawl under your dash and take a look at the wiring around your brake pedal. Maybe it is rubbing against some wiring? Easy to check, so I would start there first.
BTW, there are no indicator lights telling you if you have light bulbs burned out. You just need to do a visual check periodically.
ORIGINAL: Winshawn
I will definitely check around the brake pedal to see if there is any wire rub going on. I'll check around the back hatch also. I am not sure where else there might be any rub going on.
97GSpower
12-09-2005 10:46 AM
