Problem with '00 MS-LS internal lighting
Old Feb 23, 2007 | 12:45 PM
Winshawn's Avatar
Default RE: Problem with '00 MS-LS internal lighting
Simple things first. Crawl under your dash and take a look at the wiring around your brake pedal. Maybe it is rubbing against some wiring? Easy to check, so I would start there first.
BTW, there are no indicator lights telling you if you have light bulbs burned out. You just need to do a visual check periodically.
Old Feb 23, 2007 | 12:56 PM
MontSport2000LS's Avatar
ORIGINAL: Winshawn
Ahh, I just thought my bulb indicator was crapped out, glad to be informed otherwise. At least I now know I need to check them myself and stop looking to the dashboard for the info.
I will definitely check around the brake pedal to see if there is any wire rub going on. I'll check around the back hatch also. I am not sure where else there might be any rub going on.
LuisD
Aug 11, 2011 10:24 PM
BlackMurcielago
Jun 1, 2007 12:38 PM
Josef
Jan 15, 2005 04:49 PM
denverlicious
Sep 13, 2004 11:53 AM
