Pulsating brakes
Old Aug 14, 2006 | 01:27 PM
Winshawn's Avatar
Default Pulsating brakes
So, my '03 has developed a pulsating brake problem. I know that I will need to turn the rotors or just replace them in order to fix the problem. However, I was wondering if this was a common problem on newer Mitsu's? The vehicle is driven pretty gently and is not used for towing. Either the original rotors are crappy or when I had my wheels rebalanced and rotated they overtorqued the lug nuts. Any input on this issue? Any recommendation on good aftermarket rotors?
Old Aug 14, 2006 | 04:18 PM
Default RE: Pulsating brakes
I have heard alot about the warping of factory mitsu rotors. They basically suck in my opinion. Just spend the extra couple bucks and get yourself some decent brembo ones and you will never have the problem!
Old Aug 14, 2006 | 08:24 PM
Manybrews's Avatar
get them machined on the car.. removal for machining or replacing is ancient history.
Old Aug 14, 2006 | 09:07 PM
Winshawn's Avatar
ORIGINAL: Manybrews
Really? Why?
Old Aug 14, 2006 | 10:45 PM
montero1's Avatar
Yes, the stock rotors are junk. I had mine turned under warranty at 4200 miles, again at 13,000 miles, 1 last time at 20k, then I replaced at 30k.
Get some of these:
http://www.frozenrotors.com/
Old Aug 15, 2006 | 01:07 AM
Manybrews's Avatar
ORIGINAL: Winshawn
ORIGINAL: Manybrews
Really? Why?
because turning them on the car compensates for not only hub/axle/bearing wear and runout, but also puts a preloaded torque on the studs, putting them in their normally "stretched" position as though the rim was on.
I dont know any manufacturer that doesnt REQUIRE rotors to be machined on the car for warranty. If a mitsu dealer machines a rotor, the claim will be declined if not done on the car.
it cuts the potential future warping of that disc by about 75 percent.
Old Sep 13, 2006 | 11:36 PM
Urban Gorilla's Avatar
Also after heavy breaking remember to get your foot off the pedal as the pads will act as an insulator and trap in heat while the rest of the rotor cools.
killermagik
Aug 8, 2016 01:16 PM
zerospeedauto
Feb 24, 2015 09:22 PM
msport_2_outlander
Jan 9, 2015 07:30 AM
ecotrans
Jan 12, 2004 09:21 PM
rollin_hard
Oct 29, 2003 03:52 PM
