Rear Axle Seal Replacement
Old Jul 13, 2021 | 02:52 PM
Naeos_Valkarian's Avatar
Default Rear Axle Seal Replacement
It's time for new axle seals and bearings on the rear, I'm slinging diff fluid all over back there. I know very little about the seals and bearings on a solid axle setup. I need to know how many seals and bearings each end will need.
I assume two sets of bearings and seals for each side but this is going to be a learning experience for sure. I've watched a few videos but they don't ever mention anything about inner seals or bearings so I'm not sure if they exist.
Any tips or tricks you guys can give me would be very appreciated.
Thanks
specs:
1998 Montero Sport LS 3.0 RWD with open diff.
Old Jul 14, 2021 | 09:35 PM
No experience with rebuilding rear diff on Montero. I hope these diagrams might help you with understanding what sorts of parts you will encounter in the process as well as to locate needed parts for the rebuild. I do not know exact setup you have, so you may want to check by VIN to make sure to have the right parts diagram.
Best of luck.
https://tinyurl.com/ymwdu2z9
Old Jul 15, 2021 | 12:31 PM
Best of luck.
Wow, that website is amazing. All my searching and I never saw that through 10s of google search pages. This gives me what I needed to begin collecting parts! Thank you so much!
The diagrams on this site are so much more in depth and detailed than my fsm.
wilde
May 21, 2018 10:14 PM
jtop
Mar 20, 2015 12:28 PM
hallca5
Jun 16, 2013 12:08 AM
pepe
Jun 29, 2011 12:52 PM
