2001 left sprocket spring action
Old Jul 15, 2021 | 03:14 PM
Kalomar's Avatar
Default 2001 left sprocket spring action
Hello ladies and gentlemen !
I am new to the form....I have a 2001 Mitsubishi Montero Sport . She's a great girl but she jumped her timing belt and am replacing it. But when I got to lining up the timing marks the left camshaft sprocket, she has a spring that snaps it to the left or right !! Is there a specific tool that will hold it in place to but the belt on??
Any help would be Great !!!
Gman
Old Jul 15, 2021 | 06:47 PM
You need a camshaft holder wrench. It will help you to move the sprocket into the right position and hold it for timing alignment. Mitsubishi FSM specifies a tool that is just for Montero engines, but I found that other makes/brands of tool work just the same. Here is an example:
Amazon Amazon
I have one that has teeth that can be changed to accommodate different sprocket depth. But I've only used the longest/deepest teeth on Montero sprockets. Look around and find the one that you think will give you most flexibility. They are not expensive any more.
kc2llw
Aug 24, 2019 07:42 PM
newmont
Sep 12, 2018 05:29 AM
dragonov7
Nov 12, 2014 12:57 PM
ronfinch
Mar 18, 2005 12:24 PM
Spyder
Mar 18, 2005 10:50 AM
