Rear Differential help
Hey guys,
I blew my diff on my 2000 Montero Sport 3.0L LS. It has the 4.90 gear ratio. I've been searching for a replacement differential for the past month or two and haven't been able to find an exact match. Are these rears interchangeable? I called the dealer and gave my VIN and the donor VIN and I can not find matching part numbers. I'd like to find an exact match, but am I wasting my time? Any help is appreciated. Thanks |
Have you already checked all of your local pick-and-pull yards
Are you only interested in installing used parts? If you're considering new, check this site out: https://www.mitsubishiparts.com/oe_parts_catalog.html |
I've tried most of my local yards and haven't been able to find an exact match. would any 4.90 non-locking swap right in? or do these vary in size depending on wheel size, etc.?
where are you located ????????????????
^new jersey
Would like help with 03 montero reardiff plug type and location is the fill plug the one on top and if so what is the best way to remove? Thanks hawzdawg
Can anyone help with plug type and location for 03 montero rear diff?thanks hawzdawg
