Replacing 100% coolant 2001 Montero Sport 3.0L
Old Dec 29, 2017 | 07:50 PM
walacereid's Avatar
Default Replacing 100% coolant 2001 Montero Sport 3.0L
Is there any reason I can't just remove the thermostat and upper hose, then put a running garden hose in the upper hose, and start the car for 10 minutes?
Won't all the existing coolant just come out the hole where the thermostat was?
Then just pour a few gallons of distilled water in the hose, then make sure I get 4.75 quarts of anti freeze in it!
Old Dec 30, 2017 | 12:43 PM
You are going to make one hell of a mess...
The thermostat outlet is where the coolant will come out when the engine is running. Sticking a garden hose on it will not help - you'll be fighting against the water pump. If you can, you'll be better off rigging something to connect water hose to the bottom radiator hose going to the engine.
jer01mont
28
Nov 4, 2019 07:53 PM
Superstar
Sep 22, 2015 10:40 AM
leejm12
Jul 27, 2013 05:57 PM
jjmee27
Aug 25, 2011 09:14 AM
ruski
Dec 30, 2010 05:32 PM
