Reverse Problems
Old May 31, 2012 | 09:55 PM
Suhaill's Avatar
Default Reverse Problems
My Montero Sport 1998 (180,000 miles)
has no reverse in the morning or after it sat there for 1 hr.
What could it be?
Old Jun 1, 2012 | 07:28 PM
mxmikie's Avatar
find a transmission additive with toulene in it and try a bottle
Old Jun 1, 2012 | 08:40 PM
Mr. Z.'s Avatar
Speaking of this, when was the last time you flushed your transmission and completed a fluid exchange?
(I'd recommend using only MM ATF.)
Old Jun 1, 2012 | 08:58 PM
Suhaill's Avatar
Thanks for your replies!!
i bought the car 5 days ago..
Drive, 1 and 2 works fine.
I called a transmission work shop they said it could be the reverse seals, a $800 job.
The fluid seems ok to me but is a little over fill.
Does bad fluid do reverse problems?
Anyways tomorrow i will add the additive.
Old Jun 2, 2012 | 10:50 AM
Mr. Z.'s Avatar
Since you just purchased the rig, I'd begin with a complete fluid exchange with MM ATF (not just a drain and fill). Did the vehicle come with a service record where you can trace the last transmission service and find out what fluid was used?
When you check the level of the transmission fluid:
-bring the transmission to operating temp.
-run it through all of the positions (R,D,P,N) leaving it in each for a bit.
-place the selector in N with the rig running
-check the fluid level
-it should be up near the hot indicator (but not above)
I'd also suggest changing the fluids in both differentials and the transfer case (all of these are just a drain and fill service, easy DIY).
Old Jun 2, 2012 | 12:47 PM
Suhaill's Avatar
The fluid level is about half inch above the hot mark.
Sorry for my ignorance, what does mean MM ATF?
Old Jun 2, 2012 | 10:52 PM
Mr. Z.'s Avatar
Mitsubishi Motors Automatic Transmission Fluid.
Here is a link to source the fluid if you don't have a dealer near you.
Scroll down to the page to find it.
STM: FLUIDS | ENGINE OIL | TRANSMISSION | ATF | TRANSFER CASE
Is the dip stick reading .5 inches above the hot line when checked according to my previous post?
Old Jun 3, 2012 | 08:36 AM
Suhaill's Avatar
Yes, the dip stick is reading .5 inches above the hot line when checked according to your previous post
Old Jun 3, 2012 | 10:16 AM
BigJoeRice's Avatar
"Mitsubishi Motors AutomaticTransmission Fluid.
Here is a link to source the fluid if you don't have a dealer near you."
I tried to buy this at my local dealer and was told they only had it in "big drums" and told me to go to NAPA or O'Reilly. Is there a good alternative?
Old Jun 3, 2012 | 11:00 AM
Mr. Z.'s Avatar
You can order it from the folks at 'streettunedmotorsports'- I put the link to fluids in a previous post.
