Second (rear) seat fold troubles
Old Jan 1, 2008 | 06:17 PM
tj90's Avatar
Default Second (rear) seat fold troubles
I have an 03 limited with a rear seat folding issue. Its always been a problem but it seems to be getting worse. Whenever I try to fold up the 2nd seat, the seatback will fold down properly, but it will not lift in the up position. I used to be able to slam the seat down and try again and it would work, now nothing. I consulted the manual and followed the directions with no help. Ive siliconed the lever and engagement mechanism at the bottom. Is there an adjustment that I can make? The problem is on the double bench side. The single seat seems to work as its supposed to...
THanks,
TJ
Old Jan 1, 2008 | 06:47 PM
tj90's Avatar
Default RE: Second (rear) seat fold troubles
I think I fixed the problem -
Take the bottom seat cover off (about 10 phillips screws) and you will find a cable adjustment. The one cable looked loose so I tightened tghe slack out of it. Now you dont have to slam anything@@@!!!!!
Old Jan 31, 2014 | 10:30 AM
04MONTY's Avatar
Default seat cover removal
whre are the screws you are referring to? how do you access them
Old Oct 2, 2014 | 03:57 PM
deadreckoning86's Avatar
Default yes i need to know this too
how did u fix yours. mine has not worked since i bought the car
Old Mar 4, 2015 | 06:25 PM
steakster's Avatar
Default Montero rear seats
Me, too. Where do you access the screws to remove the seat cushion?
Old Mar 5, 2015 | 05:08 PM
MrInternational's Avatar
Probably could benefit from the seat removal process as well. Granted I have the opposite problem in that I can only fold down the seat but can't roll it forward.
Old Mar 6, 2015 | 10:26 AM
steakster's Avatar
Default Montero rear seat tilt/fold
Figured out the process for tilting the 2nd row seat forward for the 2002 Montero. (1) Use only the slide release on the seat back - NOT the handle lever by the seat bottom (2) Do NOT fold the seat back completely down on to the seat bottom (3) Slide/hold the release on the seat back with one hand - fold the the seat back just 20% or so - then grab underneath, behind the seat bottom with the other hand and lift. The seat should easily roll up and over.
Ha! I have the owner's manual and still couldn't figure it out. I hope this helps.
Old Mar 7, 2015 | 09:33 PM
Thanks for the heads up. I will give this a try.
Old Mar 26, 2017 | 03:14 PM
alvaro5349's Avatar
Default Than you!!
Thank you very much!! Since I got my Montero I was trying to figure out a way to move or slide my 2nd seat row forward and finally got it.
thanks again!
Old May 22, 2017 | 12:31 AM
DZD's Avatar
DZD
UNBELIEVABLE! I've had this issue for years where I sometimes (more often than not) could not fold the passenger side rear seat all the way forward. I could fold the back part down - but would often not be able to get it to flip up.
With these instructions - I can now do it EVERY single time. THANK YOU!
