Originally Posted by zoom33
(Post 260549)
At what mileage did you have this issue at as I am curious now and what are the signs?
I have an '03 Limited that I have owned since new, currently with 70k miles. The problems so far have been minor:
- "check engine" light that required replacement of the O2 sensor under warranty - a weird vibration from the rubber trim on the windshield (only on hot days) when running above 70 mph; fixed with some silicon adhesive - a split in the vinyl part of the driver's seat due to wear - fading and bubbling of the clearcoat on the spare tire cover, replaced under warranty - power antenna finally died (mechanism wore out, working on fixing now) It's on the third set of brake pads, and other than that, all I have done is changed the oil (Mobil 1 every 10k) and tranny fluid. The gas mileage is truly horrendous (at least in California), 13 in town and maybe a best of 18-19 on the highway. These are big, heavy beasts and take a lot of gas to get moving. As you are looking, be sure to find a truck with the 5 speed auto; this was standard on the Limited, I think optional on the others. The engine is otherwise a little small for such a heavy vehicle. |
Montero Gas Mileage Vs Performance
I just bought an 02 Sport w/ 3.0 2wd and because of the low HP the acceleration lacks and I try and compensate by giving it more gas. Hince poor gas mileage around town and in heavy traffic. But over all down the road on the hwy it does pretty good. Probably somewhere in the low twenties with no load. Not bad for an SUV with the cargo space it provides. I would never try and pull anything with it it just doesn't have the guts.
I am looking for anyone that has had any success in upgrading performance such as removing the metered mass airflow sensor and replacing with open source filters and getting rid of the air box. Anyone?? |
Sunroof & Sundry
1 Attachment(s)
Out of curiosity, does anyone know how to go about removing the interior sun shade for a 97 Monty Sport LS so I can re-cover it? Padding upholstery and adhesive aren't a problem; I found that. I just can't find how to remove the interior collapseable sun shade from the sunroof in any of the service manuals I've looked at.
I think I may be stuck with removing only the interior roof paneling then unhitching the interior sunroof panel, reupholstering or replacing it, and then reattaching the roof interior. If there's an easier way to do it, though, I'd like to know if anyone knows one. |
rdmckann, I'm having the opposite problem. I got the sunshade out with little problem, but can't find where to buy the replacement upholstery. I'm tempted to just glue/tape the old stuff back on. Where did you order the replacement upholstery and glue? Were there instructions? Was it difficult?
(Post 260549)
