Skid plates for 03-06
Old Aug 3, 2006 | 07:25 PM
montero1's Avatar
Default Skid plates for 03-06
Do the 06 Monteroes come with a factory skidplate that covers the transfer case? I know my 03 doesn't, but I've heard later models did..........
Old Aug 7, 2006 | 01:50 PM
off roader's Avatar
Default RE: Skid plates for 03-06
You can look under one at the local dealerships.
I know the Gen I's and Gen II's and Gen 2.5's come with transfer case skid plates.
Old Aug 7, 2006 | 08:49 PM
montero1's Avatar
I tried, but none of the 3 Mitsu dealers near me even have any Monteros left. I'd prefer to get one aftermarket, but I can't find anyone that makes 'em.
One ***** SERVICE MANAGER tried to tell me that some full size Monteros were made with just 2 wd. I just thought I'd stop in and see if there were any in for service or if the Service Manager knew off hand...........
Old Aug 7, 2006 | 09:12 PM
off roader's Avatar
What dealership was that? He was probably confusing your Montero with the Montero Sports. Sports did have some 2 wd versions available which was a surprise to me when i learned that.
Nobody in N. America will make those as a standard product. You can probably get a local decent fabricator to make a set up for you. That's what I did when I upgraded my original transfer case skid plate to one made using 1/4" steel plate. The skid plate is no longer an issue but the skid plate mounts are bending now.[&:]
Old Aug 8, 2006 | 12:45 AM
Manybrews's Avatar
the full size does not have any skid plates on the transfer case.
Old Aug 8, 2006 | 12:20 PM
off roader's Avatar
ORIGINAL: Manybrews
To clarify... I assume you mean the gen III or '03-'06 full size monty's?
Old Aug 8, 2006 | 06:51 PM
Manybrews's Avatar
ORIGINAL: off roader
ORIGINAL: Manybrews
actually, it would be the 01-06 monteros.
they do have front end skid plates (one steel, one plastic), but nothing else.
Old Aug 9, 2006 | 08:48 AM
montero1's Avatar
Default Skid plates for 01-06 Montero Full Size
I don't even call those things on the front, skid plates....... more like Splash Guards. I need one like my Jeep had, that is made out of thick enough metal to support the weight of the vehicle, or can at least take a good hit by a large rock.
Old Aug 10, 2006 | 03:13 PM
off roader's Avatar
Default RE: Skid plates for 01-06 Montero Full Size
LOL, I wouldn't compare a stock Gen I/II Montero to a stock Jeep (TJ, Cherokee, Grand Cherokee). But then again, I guess that's why they say jeeps are built, and not bought.
I agree with you though that those are splash guards more than they are skid plates. Any skidding with those and you'll be on your oil pan, etc. in a heartbeat.
Old Aug 10, 2006 | 04:35 PM
montero1's Avatar
Did I do any comparisons to the vehicle, or did I just reference the Skid plate?
