Something is draining the battery
Old Jun 12, 2013 | 05:13 PM
sidclaim's Avatar
Default Something is draining the battery
I have 97 Montero Sport. I was told by auto zone and advance auto that my battery is going bad so I replaced it. If I drive the vehicle everyday it will start, if I don't drive the vehicle for more than 3 days, the battery is dead. Alternator output around 14vdc. I disconnected the negative wire from battery. I checked with fluke multi meter on F2 fuse (engine compartment fuse box) to ground, I'll read .4 ohm with column switch in OFF position. Fuses F1,3,4 and 5 are ok. No blown fuse. All lights work. Even check lights at night to make sure nothing is ON. I installed battery quick disconnect just in case I don't drive it for 3 days or more. It's hard to continue troubleshoot without any electrical wiring diagram. Any suggestion? Where can I find wiring diagram?
masterchef
Aug 6, 2012 07:18 PM
moon55
Apr 1, 2011 05:01 PM
gstgurl
May 13, 2009 08:33 AM
Montero Momma
Jan 5, 2007 11:00 PM
micahman
May 10, 2006 02:16 AM
