spark plug wire set
Old Jan 28, 2015 | 02:24 AM
yasuji514's Avatar
Default spark plug wire set
Need new spark plug wire set, ebay has many for sale. the coil ends have 4 at 90 degrees bend and 2 as straight ends. My factory coil ends are all 90 degrees bend. What is the story here? "03 Mitsu. mony sport 3.0i. Thanks in advance.
Old Jan 28, 2015 | 03:36 PM
Akzle's Avatar
the story is you need a new spark plug wire set, ebay has many for sale. the coil ends have 4 at 90 degrees bend and 2 as straight ends. My factory coil ends are all 90 degrees bend.
...apparently.
is it so difficult to go to an auto parts store?
Old Jan 29, 2015 | 01:10 AM
OEM set is designed for this specific engine. Aftermarket sets are designed to fit many different applications with some "fudge" factor. I've used OEM set as well as an aftermarket one. The OEM fits like a glove - all wires are correct length and route perfectly to where they need to go. Aftermarket works, but you have too long wires that are snaking around and you have to loop and secure them so they don't get in the way of other things. It does work but not pretty.
The more important question - why Ebay? I noticed that frequently you can find a better deal on the same aftermarket parts form a retailer other than Ebay. Look around, there are many more choices out there.
Old Jan 29, 2015 | 07:36 AM
2001Mitch3.5XS's Avatar
I totally agree with Hunter, I got most of my top and front end rebuild kits from Advanced Auto in my neighborhood.
navigateon22
Dec 25, 2012 07:24 PM
djmanm
May 2, 2009 09:04 AM
Setinebach922
Feb 23, 2008 03:52 AM
spyder4g63t
Oct 30, 2006 09:07 PM
faded2
Jan 19, 2006 08:43 AM
