Stolen Catilytic converter--O2 sensor issues
Old Dec 18, 2021 | 02:34 PM
Campana's Avatar
Now we are getting some where--Baffled, Me too. But I think your most recent diagramm says it all -it has one 02 sensor before the cat and one after--but the guys who stole the cat prob cut that along with the cat--so I need to get this sucker up in the air and try to find the remnants of the second 02 sensor wire--then get a bung hole welded in after the cat. what fun!--then I can start on the egr codes and oil leaks--oh and the battery drain as well--did you say Car Loan? Lol.
Thanks for you patient help!!
Old Jan 22, 2022 | 04:49 AM
Campana's Avatar
Default 4--o2 ?or 3-o2?--no 2-o2
Update: So I was able to find the remnants of second O2 sensor connection--and had the guys who installed the cat weld a new bung hole after the Cat--and we are in business ! Thanyou HunterD!!
Old Jan 22, 2022 | 12:50 PM
Campana's Avatar
However still throwing 02 sensor codes--Maybe fuse for 02 sensor heater? any I dea where that might be?
Old Jan 23, 2022 | 10:32 AM
What code ate you getting?
Old Jan 23, 2022 | 10:41 AM
Campana's Avatar
p0136, p0141
bank 1 sensor 2 malfunction, and then bank1 sensor 2 heater malfunction--also getting p0400-egr but that's a seperate issue
was thinking that maybe its either not getting powered up --maybe damage to connector when they pulled wires loose
Old Jan 23, 2022 | 08:25 PM
Both of these codes point to the same sensor. That's the good news. It's possible that couple of the wires just got connected wrong. I don't know if your new sensor was just plugged in, or if the shop had to install a new plug to replace what was cut/ripped out. It is also possible that in the prosess of stealing your cat converter, the thieves pulled on the harness, causing some additional damage to the wires somewhere further up, and that is what's throwing the codes.
bluvert89
Apr 10, 2014 09:49 PM
Medger
Apr 23, 2013 03:18 PM
pillpushr2001
Oct 2, 2011 11:55 AM
JOE M
Nov 19, 2008 09:44 AM
gregkel
Jun 7, 2007 02:04 PM
