Transfer Case Fluid
Old Dec 28, 2009 | 12:41 AM
sidney004's Avatar
Default Transfer Case Fluid
Manual calls for a GL-4 75-90 yet most over the counter gear oils are
GL-5 "suitable for use in GL-4 applications" What brand and classification do you recommend? 3 quart capacity, correct?
Old Dec 29, 2009 | 09:32 PM
Tantrix's Avatar
I use 80-90w from the front wheels to the back wheels in my '92 Montero. The front & rear differential and the transfer case all get 80w-90.
As far as capacity goes, pump it in until it is spewing from the filler hole, then put the filler plug back on quick as possible.
Old Jan 1, 2010 | 03:49 PM
Skiddy's Avatar
Try CRC Sta-Lube...they have a GL-4 rated gear oil (it's 85W-90 which is still fine).
Turbo351
Mar 7, 2025 04:07 PM
mrlimey
Jan 26, 2018 11:12 PM
nate5023
Nov 11, 2004 12:43 AM
Raced Guy
Aug 9, 2004 05:00 PM
magicman909
Jun 4, 2004 04:00 PM
