Transmission problem
Old Aug 11, 2006 | 09:51 AM
mucolk's Avatar
Default Transmission problem
Hi All
I got a 2001 montero(triptronic transmission). when I start the vehicle in the mornings the forward gears wont engage till the engine heat is significantly high. So normally I have to switch on the vehicle and stay about 30 mintues before going any where[:'(]. any thoughts on whats wrong with this.
Thanks
Mucolk
Old Aug 11, 2006 | 02:25 PM
Manybrews's Avatar
Default RE: Transmission problem
have you checked the fluid level at least?
Old Aug 11, 2006 | 04:11 PM
off roader's Avatar
While checking the level also check how it looks. If you put a dime sized drop on your hand, it should be fairly clear not murky/cloudy. If it is murky don't just add fluid, also have it flushed. Alternately, the tranny may need rebuilding but mitsu auto trannys are pretty rock solid if you take care of them. I frequently hear of them lasting 200k+ miles w/out any rebuilds, just fluid changes.
Old Aug 12, 2006 | 12:58 AM
mucolk's Avatar
yes I did change the oil frequently.
what will it cost me to rebuild the transmission if there is no alternative.
Old Dec 5, 2006 | 05:22 PM
nternlframe's Avatar
I had the same exact problem this past week and this morning was really cold. It took almost 5 seconds for the forward gear to engage, almost got t-boned because it would not kick into gear. i checked my fluid levels and they are fine. What did you end up doing about your problem.
03Sport
May 3, 2006 02:20 PM
mysterio2099
Mar 10, 2006 01:53 PM
andrewfrank9
Mar 2, 2006 10:22 AM
office888
Nov 20, 2005 06:31 PM
fordmanturnedmitz
Oct 29, 2004 12:49 AM
