turn signal and brakes lights?
Old Dec 3, 2007 | 01:55 PM
foutong's Avatar
Default turn signal and brakes lights?
i have a 98 montero. the tail lights wasnt working. i fixed it by replacing the brake switch under the dash. and now i just noticed that when i step on the brakes my left turn blinker(front) lights up as if it was a brake light. on top of that my left signal doesnt work, while the right is fine. also the hazards either didnt work or worked very very slowly i cant remember correctly. has anyone ever had this problem? if so know the fix? i'm guessing its a short on the wiring somewhere.
Old Dec 3, 2007 | 02:50 PM
dsm1990gsx's Avatar
Default RE: turn signal and brakes lights?
Check the wiring at the brake switch.
Old Dec 3, 2007 | 05:25 PM
foutong's Avatar
ok so i looked under the dash again and noticed that there is another plug harness next to the brakelight switch. its a t harness anyone know where it goes to? i looked around and dont see where it would plug in.
Old Dec 4, 2007 | 05:44 AM
foutong's Avatar
a few things that were done cleaning of the battery removal, unmounting of the fuse box, playing with some of the things under the dash unpluging of the turn signal and now everything is almost perfect. one last thing is that the hazzards are still not working. it doesnt even blink now.
ehsanabria
Sep 22, 2022 06:22 PM
msport_2_outlander
Jan 9, 2015 07:30 AM
capecodder
Aug 4, 2007 08:32 PM
ricketter
Aug 17, 2006 03:21 PM
dornstar
May 22, 2006 04:58 PM
